Hi
Hoping someone might be able to help or at least advise if they have had the same issue with their Scrambler.
My Urban Enduro 2015 has had an issue for over 12 months that my local Ducati dealer (with help from Ducati in Australia) has not been able to resolve with the idle.
The bikes revs drop on idle to a point where the headlight begins to dim and flash with the RPM's bouncing and eventually stalls.
When riding, the bike coughs an jerks to the point of being dangerous. The issue is intermittent and can occur when the bike is hot or cold. Some days it is fine and others it is a struggle to control and am losing confidence in the bike.
The best way I can describe the issue under load is like a bike reaching the rev limiter and it just coughs and snatches jerking the bike and rider back and forth like it is running on a single piston.
Sometimes I get an ENGINE error on the dash.
The dealer has done the following (on the many visits I've had):
1) Run diagnostic reports which do not show any problem;
2) Adjusted the stepper motor and parameters - this seemed to show improvement, but did not resolve the issue and after a few rides returned back to the way it was;
3) Corrected an issue with the relationship between the idle speed control valve and the throttle valve butterfly - this also showed improvement before returning to the way it was.
4) Replaced the MAP sensor.
Hoping someone has experienced the same and can provide a solution... I love the bike when it is running smoothly, but when this issue kicks in I feel like running it off a cliff!!
Help!!
I have a video of the issue but the site won't allow it to be uploaded due to the size of the file.
Help!!
