If you keep up your service intervals.
What mileage did you change the chain and sprockets and what did you get?32500 KMi. Runs like new. Has never burned a drop of oil. Have only changed chains, sprockets, front pads other than regular schedule.
EK and DID x-ring chains. Seem to be about the same. I expect 12-15kmi using gear lube 4-500mi. Front sprocket: JTF736.15 (ebay) Rear sprocket shows no wear.What mileage did you change the chain and sprockets and what did you get?
Thanks.EK and DID x-ring chains. Seem to be about the same. I expect 12-15kmi using gear lube 4-500mi. Front sprocket: JTF736.15 (ebay) Rear sprocket shows no wear.
When renewing c&s can you go up a size Kiwi? If so what would you recommend?I have always maintained that the chain on the Scrambler is undersized at least one size and this tends to prove my thoughts. Needing to change chains and sprockets at half the distance most other bikes generally go shows how much Ducati have skimped on the engineering aspects of the Scrambler.
