1 - 11 of 11 Posts
Hi guys I´m going to be changing my rear shock this week but i dont have much kit around me.
My plan is to place a jack between the top of the tyre and the underside of the seat/frame and take the weight off the mounts by doing that.
I´m sure someone on here has used that method but i cant find the thread, anyone point me at it for any other tips?
cheers
Top girl Sarah that´s the one! He also got over the problem of access to the bottom bolt, thanks a bunch. I just couldn´t find it on the search cheers.
Glad to help, those little tips from those who've gone before make all the difference. Good luck, let us know how it goes.
Discussion Starter #5
This only partially worked for me.
i could jack up to take the weight off the shock mounts OK, and screwed out the top mount bolt fine.
but when i jacked up further to try to get access to the lower bolt past the footrest hanger, it just came to a stop.
So i put a jack under the sump and all that did was lever the rear wheel clean off the ground. The bolt hole still wouldn´t clear the footrest hanger. it wasn´t even close.
So i went and sawed 20mm off an 8mm allen key and got the bottom bolt out with that and a spanner. You have to fiddle with the jack height a bit to get the loose bolt out or it fouls the footrest hangar.
Maybe the Antipodeans who managed this had removed the cat. I can only think the tyre was hitting the cat. and limiting the loose swingarms movement.
Anyway shiny new EMC shock is in. I´ll post up a review when i have 500 miles or so on it.
Remove the black priece that holds the footrest it’s only 3 bolts and the gear lever to disconnect. It’s extremely easy and allows total access. You’ll be amazed.
Discussion Starter #7
But don´t you lose the side stand as well if you do that, i dont have any other stand.
I did think about doing that and leaning it on the car but cutting the allen key is less risky and quicker.
No the stand stays in place. I didn’t mention, depending on which exhaust you have it may be fixed to the bracket, but it is only one bolt. If you are worried why not lean the bike against a wall.
Discussion Starter #9
I don´t have a suitable wall at my place Gasman. I was sure the stand used the same bolt as the footrest hangar, oh well it´s done now.
cheers
I suspend my bike from a rafter in our garage when I need to remove a wheel or shock... Just keep the wheel slightly hovering and removal/reinstall becomes a breeze.
1 - 11 of 11 Posts
