1 - 2 of 2 Posts
I finally got this shock upgrade installed. The 461 shock has high/low speed compression, rebound, and now quick set preload adjustments with the addition of the Xtrig.
I worked with EPM Performance to source the 461 shock with the right spring and lower spring collar to allow enough room for the Xtrig preload adjuster. I bought the Xtrig directly from Technical Touch . I had to use a spring compressor to do the final spring installation once I had all the parts. I used one made by Motion Pro. The ride improvement is quite good though I'm still fine tuning the dampening settings. I have it about 95% there and am seeing how it works in more varied conditions to finish my tuning. I will follow up this post after I have the tuning exactly how I want it and have tried it in a wide variety of conditions including off-road
Here's some photos
1 - 2 of 2 Posts
