Hyperpro suspension
7704 Views 20 Replies 6 Participants Last post by  Chris75
Hey guy's, I contacted Hyperpro in Holland today. They were very helpful in giving me accurate information about there prices and told me the suspension for the scrambler (front and rear) are in development and will come out soon!
They have fix prices:
Front: €152,- (spring L/R + oil).
Rear spring: €110,-
Rear-shock: type 460 (rebound ajustable): 465,-
Rear-shock: type 461 (compleet ajustable): 734,-
Hyperpro English - Hyperpro Safety Control
Perhaps something to consider as an alternative... . Let me know what u think.
1 - 20 of 21 Posts
Hey Chris, who did you talk to at HyperPro? I asked the German Distributor and they claim nothing is ready by now but maybe under development... In addition: To my understanding there is only one spring in the stock setup (right fork leg) and if their solution really consists of two new springs l/r they would need to supply the cartridge on the left as well I guess...?
Look for a cartridge like andreani/ohlins having hydraulic registers. Just the spring is almost useless
You could be right, but out of the hundreds of forks I've stripped I've yet to see just one sided spring. I have however found a few where one leg takes care of compression damping and the other the rebound. The springs or 'maybe' spring is preload.
Could not agree more - weird design but true story. Here is proof from the service manual and explo-view... And yes, there IS a preload-plastic-tubing preloading the one spring and I wonder if shortening that tube would smooth out the ride of the lighter pilots around here... ;-) Low budget improvement like putting the rear shock on the weakest position maybe...?
Text Drawing Design Sketch Font
Auto part Automotive engine part
There ye go, first time for everything. Shortening the sleeve will do what a dial would do normally. I think the best place for these is in the scrap skip.
The guys name is John Troost. They are situated in Holland. You can contact him at [email protected].
He contacted me the other day asking if I would mind lending them my bike for a week to setup the scrambler in general. I would get the suspension for free that way, front and rear springs, no shock.
Didn't know about the one spring setup. When I talked to the guy I presumed we where talking about L+R. :oops: New to me too...
Could not agree more - weird design but true story. Here is proof from the service manual and explo-view... And yes, there IS a preload-plastic-tubing preloading the one spring and I wonder if shortening that tube would smooth out the ride of the lighter pilots around here... ;-) Low budget improvement like putting the rear shock on the weakest position maybe...? View attachment 1032 View attachment 1033
Sorry to disappoint you but that's the way Ducati show them in the parts list. It is the same for the Superbikes, Multis, STs etc. Although there are 2 springs they only illustrate 1. Same for some of the other components that are duplicated as well. The accompanying parts list will say something like " 20. (Part no...) Spring Qty 2"
That not what it says below the parts diagram above -
I can't say from personal experience just what I read above, and it's certainly a strange design, whose only merit would appear to be cost cutting.
this evening I'm going to check the ORIGNAL DUCATI INNER CARTRIDGE I'm storing on my garage since I've replaced fitting the Andreani/Ohlins... will see how many spring(s) they gave me back ;)
I stand corrected then. That is weird.
That is weird.
Definitely. I'll be interested to hear confirmation first hand from Hedonism later. It would account for the differient oil capacity for each leg though.
We have supporting vendors as members on here who have probably forgotten more that I have learned about suspension. Surely someone can confirm either way by now.
self explanatory
this is what Andreani gave me back
....this is what Andreani gave me back
Definitely, two springs in there then.
Clip art
Whoever wrote the excerpt from the workshop manual above was clearly on work experience.
Okay guys, sorry for the confusion, I guess the tech writer of the workshop manual was either blind or an idiot or anything in combination or in between... Thanks Hedonism for clarification!
So, normal shocks, springs left and right. :rolleyes:o_O
So the different oil levels are because one side is for rebound and the other for compression, just what Hedonism showed in the description of the new Andreani / Öhlins Combo, right?
I can confirm that one side is for compression and the other for rebound, but don't know abt oil levels
of course Adnreani / Ohlins has 2 springs as well and relevant preloading registers are on BOTH sides
self explanatory
Thank you !!
We're not as out of touch as I was starting to think, eh Derek.
I'll need to climb into the scrap skip and get them back.
1 - 20 of 21 Posts
