I was bored after I got home tonight so I pulled off my rear shock.
Since I didn't want to pull the passenger peg mount (swingarm bolt) I sawed an 8mm allen wrench to make it shorter so I could remove the bolt at the lower mount. That worked and there's barely room to remove the bolt.
I used a car jack under the engine and had my front wheel chocked. That way I could get the height just right to unload the suspension and easily pull the bolt out of the lower mount first. If you get the jack just right you can finish unscrewing it with your fingers.
The top shock mount has a one-time-use sort of nut on the back side of the bolt. It's 15mm and my box wrench barely fit back there to hold it still while I unbolted it.
So what did I learn? Three things.
1) Crud can collect down under the lower mount. I had some rocks in the swing arm just chilling.
2) I thought the shock was Sachs according to literature I'd read, but it looks like it's a KYB?? What gives? edit:// I must have read wrong. Kayaba is spec'd
3) Like I had already seen on another forum when someone else pulled off their shock, the lower bushing is crapping out and I only have 2000 miles on my bike. The rubber is cracked and the eyelet is off center meaning this thing might start banging around at any moment. Lovely...
I cleaned out the rocks and reinstalled the shock with no drama. I had to use a magnet to get the shim washer out of the lower mount and getting the washer back in took a bit of wiggle work. Otherwise the front wheel chock and car jack competed for MVP in terms of what tools I used. Don't pull your shock off unless you think you know what you're doing.
