I have found that if my bike is unused for 2 to 3 weeks, the rear brake light stops working. I am 99% sure that the cause is the "switch plunger" having some stiction issues - it doesn't release fully when the pedal is depressed. It's easily fixed when is manually push it in and back with a flat screwdriver blade. Once it starts working again it works consistently until it sits again for a couple of weeks. I've thought of spraying it with WD40 but don't want to contaminate anything inside the switch mechanism. Anybody seen this issue or have thoughts?
Thanks,
Kent.
Thanks,
Kent.
