hi guys
I am having this issue which I am not sure If I am going to explain correctly - I mean I was not really able to find the word that describes the noise I hear - ...
when going to 4th to 5th or 6th, happens mostly when going from 5th to 6th and also I am seeing when going to low gears I think it happens when going from 5th to 4th gear
the issue is I change gears using the shifter as usual then I hear a noise like coming from engine and what I have to do is to shift again to the gear I was intended to go
let's say I mean 5th gear and I shift to 6th gear but I get that noise like I am in 5.5 gear so I have to apply clutch again and shift again to have everything in order
it's like the gear try to shift but it stays engaging and i have to shift again to let it finally engage the gear I want my motorcycle to go
any idea?
thanks a lot
any idea?
thanks a lot
