1 - 7 of 7 Posts
Hey everyone. New scrambler owner here and have run into a gas leak issue over the past month or so. Seems like the tank has been under pressure after a short ride once it's heated up. I've been having to open the gas cap after a ride just to relieve the pressure and even then I've noticed a small "pssssss" coming from underneath the tank with some gas leaking. If I forget to open the gas cap, I've come back to a small puddle of gas underneath the bike.
At first, it looked as if the pressure had caused a crack in the tank, but after removing the tank and looking underneath, there are several spots where the paint has been worn off or cracked near bends/kinks in the tank design.
Curious what to do next... pressure test to see if there's a leak in the tank? Replace the breather hose where the apparent kink has been? Let me know what y'all think. Thanks in advance!
Wood Tints and shades Ceiling Metal Concrete
Close-up Human leg Metal Transparent material Macro photography
Automotive tire Rim Gas Automotive wheel system Auto part
Grey Wood Water Tints and shades Ladybug
Tire Wheel Automotive tire Hood Bicycle tire
Automotive tire Motor vehicle Bumper Synthetic rubber Automotive design
Liquid Water Hood Fluid Automotive lighting
I would replace the hose and add some JB weld to the area on the tank you think is leaking, if it solves the problem, you could get the tank welded in the off season or line it on the inside with a tank sealer, I have used Caswell on my older bikes with great results.
1 - 7 of 7 Posts
