Well, that's not true, they actually larger in diameter and longer. Never trust what people tell you on the internet, measure for yourself. Once the I finish painting the desert sled triple trees, it's all gong back together. I'll post some photos next weekThe sled has thinner legs. Not shure would fit
I don't think that it exists. You would have to have longer stanchion tubes and a longer shock.Small budget guys... looking for a smart cheap solution...
If it's about getting the bike higher( suspension travel is something totally different)you might be able to mount a shim between the top mount of the rear shock. Might try to get some info at a local suspension shop. If you're a heavy guy(like me) you could start by increasing the preload if you haven't adjusted the suspension yet.There's also some space above the triple tree in the front that you can drop down to increase the height.Its not about the seat. Seating position is almost perfect now and soft. Is about having an higher bike. But thanks guys
