1 - 7 of 7 Posts
Hi, I just thought I'd post a few pictures of the solution I've found for mounting soft panniers to my desert sled. The pannier racks came from China via Alibaba. It seems the kreiga ones are no longer produced but these are fine and a fraction of the cost. Also I found that by using slightly longer bolts I could retain the grab rail that uses the same mounting points. The panniers are a triumph item purchased used. They're a perfect fit giving plenty of clearance from the Arrow exhaust. I did look at cheap Chinese alternatives but wasn't sure the quality would be good enough. SW Moto seem to make a decent set of soft panniers but they're not cheap. I'm planning a trip to the Pico's mountains in Spain and the only other job to do is to go tubeless. I've got all the bits to do the job so I'll post pictures when I get on and do it.
I got the same and are awesome just didn't used does bags but mine didn't came with the rear tube. Do you buy it separately? Can you send me the link
Enviado desde mi Redmi Note 8 mediante Tapatalk
I bought the grab rail seperatly from an Italian company WRS DM Telai. If you Google them it'll come up.
Thanks but they don't make it for the 2019 I will contact them maybe they are planning to do it in the future
Kriega saddle bag brackets are still available and in stock from the Australian distributor. There was a period about 6 months ago when they were not available but things came good after then. Not sure where the story that they are no longer produced came from.
KriegaUSA emailed me yesterday confirming that the mounts are no longer produced. Any idea how to get in touch with the Australian distributor?
1 - 7 of 7 Posts
