1 - 8 of 8 Posts
I'm gonna go through my work pc tomorrow and try to find the place I bought them. The color is one shade darker in my opinion.
Discussion Starter #6
Thanks Lenny,
It's just a cheap lic. plate mount and a couple of allen head bolts.
I bought a $20 dollar lic. plate mount from a cycle shop.... you can probably get the same mount on the net for $10. It's almost a direct fit... just change the angle by bending the mount.
I removed the plastic turn signal mount and found threaded nuts in place already. Drilled 2 holes for the turn signal leads, pulled the leads out of the turn signal housing and rerouted the harness. I mounted the turn signals directly to the frame that was covered by the plastic extension. Once you remove the rear turn signals it all comes together. Really easy and really inexpensive.
The front signals can be pulled in tighter the same way. I just haven't done it yet.
Thanks! I had focused on other mods and those are finally finished. The lic plate is the last thing on my list!
1 - 8 of 8 Posts
