1 - 3 of 3 Posts
I just bought a Puig windscreen and the front brake line needs to be rotated back a little. Has anyone done this? I know you need to protect the paint and surfaces, but I just want to crack the line and move it rearwards.
Thanks Sharon
Thanks Sharon
Cracking the banjo bolt and rotating the line is easy, if you control the spanner you can loosen it just enough to allow the banjo to move with you while tightening back up by applying pressure to the line with your thumb. If you get it just right there won't be a leak or more important any air getting in.
Yers, just move the cable as above. To protect paint and finishes I just used a couple of black sticky rubber buttons. Just place where contact is made. worked a treat.
1 - 3 of 3 Posts
