I came across these:
Barracuda S-LED B-LUX Turn signals
I plan to use them on the back of the bike. They should be here this weekend.
-Bob[/QUOTE
Can you confirm whether you needed transistors with these?
Cheers!
SailorHH
I sent an email to Barracuda in Italy and they replied that I need the 10 watt resistors.Can you confirm whether you needed transistors with these?
Cheers!
SailorHH
Thanks, Bob!I sent an email to Barracuda in Italy and they replied that I need the 10 watt resistors.
I have not installed them yet. I am waiting on the LED strips for the front to arrive. They are on a slow boat from China. I'm also waiting on the Barracuda adapters for the Scrambler.
I purchased a pair of the 10 watt resistors just in case. Once everything arrives my plan is to connect them without the resistors and see what happens.
-Bob
Once the weather is clear enough and I get a chance to install them, I'll post up here.Yes I was thinking about getting the m.blaze pins too. I also like the motogadget bar end turn signals.
The others are correct - you don't need any resistors. The Scrambler has an LED tail light, so it already has the correct relays for LED lights - apparently they used them on all of the lighting circuits. I run LED bulbs now in the stock turn signals, and they were plug-and-play.Are resistors needed on the scrambler? I thought it already had relays for conventional and led signals
Very interested to see these. I am thinking of the pins for the back and the bar ends for the front.Once the weather is clear enough and I get a chance to install them, I'll post up here.
I wanted signals that were "minimalist" (read "small") and still very bright and visible from the sides as well as front / back. The Pins seemed to fit the bill. I have the signals and a bunch of posi-taps all ready to go. Not having a garage sucks.
Sorry for the late reply. A medical issue has kept me preoccupied for the past month.Thanks, Bob!
I'm looking forward to your experiences and the odd photo.:02.47-tranquillity:
SailorHH
