I'd be very interested in this. That cable is the one I have for my MTS1200 which uses the same connector but a different (Mitsubishi) ECU.Interfacing to OBD II is well known. I will post links as soon as I have a setup running.
Is this the cable you would recommend?
Ducati 4 Pin Multistrada CAN Diagnostic Connector Adaptor DDA LEDUCC16ADAP - 14.99 Lonelec Fault Code Readers ECU Diagnostic Equipment
That's terrible the display failed, any idea what happened? It really wouldn't be covered under warranty? Good luck with the app, that'd be pretty cool.my bike display has suddenly faulted a couple of weeks ago, after the shocking EUR 750 request from my dealer i decided to buy the ELM327 and the cable, and i'm starting writing an android app to replace my display.
Does anyone knows where i can find a guide to read rpm, speed, temp and other messages from the ECU (m3c, the same of the scrambler, so this applies to your forum) I am assuming they will be standard OBD2 messages, but i'm still a newbie on this technology..
any help is appreciated, thanks. for sure i will share my app with all the community if it works!
LCD display doesn't work at all after first spring startup. Seems that this failure is not so uncommon..That's terrible the display failed, any idea what happened? It really wouldn't be covered under warranty? Good luck with the app, that'd be pretty cool.
Try agagama appmy bike display has suddenly faulted a couple of weeks ago, after the shocking EUR 750 request from my dealer i decided to buy the ELM327 and the cable, and i'm starting writing an android app to replace my display.
AgamaTry agagama app
