Does anyone happen to know the OEM Gear Lever Part # or where to buy it? Or where I could find the part # if you have shop service manuals/diagrams? Thanks!
What model did you get?Does anyone know if the toe peg is removable and can be replaced with a spring loaded one on the Sled? I’m waiting on transport delivery of a 2018 model and would like to order it in advance if the lever will receive it.
https://amsducati.com/ducabike-ducati-folding-toe-peg
Just checked my stock lever. It appears that the 'peg' is pressed into the shift lever. You could probably have it drilled/pressed out, but there is no guarantee that the springy peg will be the same diameter.Thanks for the response. It’s a DS. The Ducati adjustable folding tip lever doesn’t fit the DS which seems odd given this bikes off road bias so I have no idea what to expect. Trying to avoid purchasing the expensive SW Motec lever assuming I don’t need adjustability and just want a folding tip.
Follow-up:
I looked up the gear lever part number on the link provided above and the toe peg doesn’t appear to be replaceable.
