I used this self-adhesive soft vinyl for several enhancements:
2 Pack Lifesafe Black Textured Vinyl Slip Resistant Step Strip 6 x 21 eBay
Used for mudguards (along with other materials), detail on front gas tank tabs, Dragon-S design on rear
I also used this stuff:
Cowles T5602 Edge Trim - 8 in. - Black Buy Online and Save
Used around side panels, lower edge of gas tank, mudguards
Front mudguard is a sandwich of self-adhesive vinyl with 3-M double sided adhesive tape in the middle.
Trimmed on sides with edge molding.
If it detaches, no worries...nothing to create any damage to tires or bike.
Rear mudguard is 1/4 inch thick aluminum plate with a layer of self-adhesive vinyl on inner aspect. (also a bit on outer aspect below plate & the Dragon-S sticker is cut-out from this material-gives a slightly raised look)
Luggage Attachment Rings under pillion seat are made from welded rings and nylon webbing straps held with SS hardware.
Frame hole plugs are from here: Corsair Industries Ducati Frame Plug
Levers Pazzo long, (Go-Cruise throttle holder, Throttle-Rocker-removable as needed)
GPS mount is a RAM ball mount on handle bar
OEM belly pan
Termi slip-on
Dart Flyscreen will be available soon (Midnight version)
Heated Grips have been on order since I ordered the bike (still waiting)
