Hey everyone, looking for some advice. I checked oil level last night and noticed it low. Ok, no problem. It has over 4k miles and has only had the first service at 1000 km. So I figured maybe it has burnt a little. But I looked under the engine and found this. This pics are a little hard to see as I had fitted the bash plate right after the first service. But you will get the idea. I suspect the oil filter has worked its way loose at this point, but I just noticed it last night so I haven't had the time to remove the bash plate.
Here is my question:
I called the service department at my dealer and they suggested I just take off the skid plate and see if the filter is loose, but said he hasn't seen that happening on the Scramblers yet at their particular shop. He said if its not that, to call them back and they will look at it. The bike is still under warranty, and the service was performed at their shop, so isn't it really their job to do that? To me it looks like a pretty substantial amount of oil on the pan and therefore Im a little concerned to keep riding. The bike is my daily driver year round, and I don't really have a lift or tools with me at work to check it out. Should I just demand they come pick it up and leave me a loaner? Or just quit whining and figure out if I can fix it. Just annoyed at the inconvenience of it. Keep in mind, my dealer is about 1 hour away, so dropping by isn't really an option either. What do you think?
The first shot has the bottom of the oil filter on the right. You are looking into the skid plate from above.
The second shot is underneath the pan looking up at the bottom. (Right is the front of bike) Drips are on the back edge of the bash plate. Also note, when the oil was changed at the dealer, they also coated the drain plug in what appears to be a silicone RTV sealant. It is not grease. It is hard and rubbery to the touch.
