Hi all.
I am new to this forum and would like to share the build of my Full Throttle. Firstly, i am by know means a professional in the area of what im doing, but certainly confident enough to give it a go. This is a learning curve for me so i am open to constructive criticism, suggestions and compliments.
- Firstly, the Turbo. I have chosen a Garrett G-12, mainly based off the calculations and recommendations of a local supplier. I am doing away with the muffler box and mounting the G-12 under the swingarm. The intake filter will now take place of where the exhaust pipes were and the exhaust will dump out the left side. Oil pressure will lubicate the G-12 with an inline pump returning it to the engine
- I have a PWR intercooler measuring 300mmx200mmx60mm. I have cut and modified the cooler to relocate the inlet and outlet and reduce to 2" diameter. Pipe work is 2" stainless
- Air box will now be gone and the oil cooler lowered to below the intercooler. CDI unit moved back into the frame behind the intercooler
- I will not lower the compression just yet, I plan on doing an initial dyno tune to see how it handles the boost
- Does anyone know if there is a kit to relocate the footpegs?
- Rexxer seems to be the go with tuning, can i get this in Australia?
- Is there a quick shift available to suit?
