1 - 3 of 3 Posts
It appears to me that the only paddock stand bobbins you can get for the Scrambler are ones that are connected to a bar through the rear axle. Not really much use if you want to remove the rear wheel or adjust the chain.
Are there any bobbins available that do not use a bar through the rear axle?
Thanks.
Was wondering the same. Would these be good enough the raise the rear and remove the wheel? Or will they drop out as soon as you remove the rear axle?
As soon as you pull the axle out the swing arm and whole rear of the bike will drop towards the floor, There is not way I would suggest to anybody that they use something like that it is an accident waiting to happen.
1 - 3 of 3 Posts
