41 - 60 of 74 Posts
Oh cool about the black release lever wasn't aware of that, thx. Will definitely be buying one.
Going to be installing those new Ducabike clip-on bars soon too as they give me 0.8 inches more room on each bar so not near as tight a fit as now plus a 10-degree adjustment in any direction (front/rear/up/down) which I'm sure will make for either a much more comfortable or aggressive riding position.
Those sound like it would fit much better. Also may be able to fit a mirror in the middle of the bar, rather than a bar end....
There's posts mentioning RAM mounts on all 3 of the previous pages.
-Bob
-Bob
My bad, mean't to say RAM mounts as a solution. But also just noticed someone mentioned solution in page 3, just didn't see.
Either way, this works great for my bike. Took about 10 mins to install
I have my RAM mount mounted to a custom piece I made that extends from inside of the left clip on using a well nut and long bolt. Not necessarily the best looking solution, but it works pretty well for what it is. I have a very large phone and didn't want it on top of the triple clamp. I will post a picture later.
This little setup cost me less than $4 and works great. Holds on at very high speeds... If anyone is interested, I could do a small 'write-up' here on how this all works.
Hey guys new here, but I had a different approach that may add some value. I wanted a more standard mounting option to use any type of mount, be it for a phone or otherwise. Although I’m happy to shell out some $ for good products, all told this cost me about $20 (with the mount) using a 3/8 concrete anchor and aluminum spacers -all stainless/galvanized/aluminum hardware for obvious reasons.
Can you pls tell me the instructions in detailed? Tried to get my head around it but still didnt get it.
I managed to attach a RAM mount to the left handlebar. I did it by loosening the clutch lever enough to squeeze the ram mount behind it, then tightening it all back up. The clutch isn't 100% tightened up now, maybe 95%, but it's solid and it's all working well.
I like having my phone on the left in the open space rather than the middle, where it's likely to partially obstruct the speedo panel.
In also using quad lock, which is excellent.
I have the TT iBracket and i am rly happy with it.
Graps pretty tight on the crossbar on my DS + iPhone 8.
Its not on the cheap side though...
No way I'd put a phone on a bike. Not with my crash history! :)
I would just like to mention to any new riders that there is no valid reason at all to have a mobile phone on a bike. You shouldn't be looking at a sat nav or trying to change music whilst moving, these are dangerous enough machines as they are.
Get a bluetooth enabled helmet solution like Cardo, Ejeas, etc, stick your phone somewhere safe and you can listen to sat nav directions and hear music IF you really want to - though not convinced this is even safe.
Just saying'. Not judging. We all take risks as soon as we get on a bike. I know that as well as anybody. I have the metal in me to prove it.
Ride safe guys and keep safe over this Corona period.
41 - 60 of 74 Posts
