Recently I noticed quite a bit of buzz when holding constant @ 4000 RPM, and I think I need to tighten the chain a little..
According to the manual:
Make the rear wheel turn until you find the position where chain is tightest. Set the motorcycle on the side stand. With just a finger, push down the chain at the point of measurement and release. Measure the distance (A) between the centre of the chain pins and the aluminium section of the swinging arm. It must be: A = 27 ÷ 29 mm.
1. Does it mean I need to use the swinging arm (swing arm?) as my zero ground/starting point instead of using the ground?
2. Is A referring to:
Apologies if this has been covered before as after I searched the forum, there were only 5 posts containing "chain tension".
a. Lowest point (pressed down with 1 finger) to neutral? (no finger)
ORb. Lowest point (pressed down with 1 finger) to highest point? (pressed up with 1 finger)
