Yes you can, I have had mine for 12,000 miles now. Shifts great even at redline, i have my shifter set at 95 milliseconds which is perfect. You can shift down no problem. It's so much fun to ride, I use the shifter after second gear, you can shift from first to second with the quick shifter but it feels a bit questionable so I just don't do it that often, every other gear up or down is perfect. I hope this helps, install was easy on my 2105 full throttle. Shifting at redline on fire roads going sideways is so much fun, don't try it with the stock tires though you will be picking rocks out of your teeth 😁can you fit a quick shift setup on a scrambler
which quickshifter did you get??Yes you can, I have had mine for 12,000 miles now. Shifts great even at redline, i have my shifter set at 95 milliseconds which is perfect. You can shift down no problem. It's so much fun to ride, I use the shifter after second gear, you can shift from first to second with the quick shifter but it feels a bit questionable so I just don't do it that often, every other gear up or down is perfect. I hope this helps, install was easy on my 2105 full throttle. Shifting at redline on fire roads going sideways is so much fun, don't try it with the stock tires though you will be picking rocks out of your teeth 😁
You need to explain the downshifiting. The Full Throttle doesn't have throttle by wire so I'm fairly certain you can't just tap down on a closed throttle and the quickshifter takes care of the required blip...every other gear up or down is perfect.
