i've noticed that the rear brake fluid level looks like its below the min line when parked and leaned on kickstand but is within the min and max lines when its upright. the manual doesnt specify when to check it? should i be topping it up?
how many miles on the bike?i've noticed that the rear brake fluid level looks like its below the min line when parked and leaned on kickstand but is within the min and max lines when its upright. the manual doesnt specify when to check it? should i be topping it up?
About 5600 miles. It’s due for its first major service anyway (for some reason the sixty2 has 10,000km interval vs the 800 at 12,000km intervals)how many miles on the bike?
check brake pad thickness.
brake fluid level will lower once the brake pad wears.
if you use rear braking a lot then better check pad thickness.About 5600 miles. It’s due for its first major service anyway (for some reason the sixty2 has 10,000km interval vs the 800 at 12,000km intervals)
Sent from my iPad using Tapatalk Pro
