im right at 195 pounds and the sag on my DS is 2” in the rear. Is that about right? I wish it were more for my short legs , but ride quality is more important
You place the bike on a rear stand then you lift the rear fender and while is lifted you measure with a tape the distance between rear axle and the passenger handle. Then you sit on the bike and someone else measures the distance between the rear axle and the same spot. Now the distance must be shorter and it should be shorter by 6 cm or 6,66. If it is more or less you adjust the preload accordingly.How do you accurately measure it especially as it is up + down?
