Thanks Cliff for your help.No reason for concern...
Those flashing lights are indicating the security system is on.
Cliff
8 hours...If I remember correctly, they stop after four hours?
Whatever the case, they will stop and cause no real drain on the battery.
The system is actually an immobilizer tied to your key. The engine won't start unless the ECU reads the signal from your key.
Pretty slick, huh?
Cliff
Oooh! Where can i get one of those?!You are right about that, Slaine.
I, on the other hand, would rather have an anally - accessed root canal.
