41 - 53 of 53 Posts
· Premium Member
I fitted the Classic logo, these are a lot more substantial than the Icon logos , look much nicer too, It only took me 40 min to do both sides,
First i heated them up with a small heat gun, sawed them off with fine twine, warmed the glue/foam and rolled it off with my thumb, Painted on sticky stuff remover, then went over to the other side while it soaked in ,
When I went back over, the glue etc had completely melted , just a few rubs with the credit card and a wipe over with brake cleaner and it was ready to fix the new logo,
Remember to tape a line around the top and side so you can put them back in a similar position ,;)
Interesting scenario........I am picking up my red Icon on Friday. It has been displayed in the dealership with lots of the add-ons such as Termi pipe, Scrambler luggage, all the little pie-end trim etc and it has the carbon tank panels. The bike was offered with all these without a fitting charge (as they are all already fitted), but if I didnt want them they would replace all the standard parts for me (no charge of course). I chose to save money and just go for the standard bike with a pipe upgrade.They have now left me a message to say the tank panels are hard to remove so would I like them on the bike instead of the originals at an extra cost of £95. While this is not much and I had already considered the black panels, are they really that hard to remove? is it all about risk of damage? Should I go for the carbon and have this as a cheap personal mod? I suppose if they also supply me with the original steel panels, I can decide later and get a return on the carbon ones.........What do we think??
The original (aluminum) panels and stock emblems are not hard to remove without damaging the finish. The same may not be true of the carbon panels, I just don't know. The finish may mar easily. Or it may be that the carbon panels themselves are more likely to crack in process of removing the emblems.
A factor you should maybe consider is that the finish of the aluminum panels is easily marred if you tend to ride hugging the tank with your knees. I don't know how the carbon panels hold up in this regard; it's actually the polyurethane coating that gets worn quickly on the stock pieces, and I don't know if the carbon is coated similarly or if the coating may be more robust.
Thanks for the info. Cant make my mind up still. Sounds like the price differential should indicate that the carbon panels should at least be of a superior build quality and not mar as easily, so I may just go with them. Think I'll ask them to waive the price though. I just want to get the machine home so I can stare at it....
Has anyone tried removing the paint and polishing these aluminum covers? I ordered the chrome covers back in May and am still waiting... I was told they would be in at the dealer on Dec 15th today:( So am I am thinking it is time to start polishing!
I was thinking of fabricating stainless steel side panels to match Zard pipes will need something to cover the screw
41 - 53 of 53 Posts
