1 - 7 of 7 Posts
Use a hairdryer to warm the glue and then should pull away easily. Use dental floss or fishing wire if needed.
Then clean up glue with a mild solvent.
I just used flat screwdriver covered with thick cloth. Once you got the first bit peel off you can take out the rest by hand. No paint-off
But warming followed by nylon seem more proper way to do it
Discussion Starter #7 (Edited)
Done :)
Talked to the local color store. I use Sonax asphalt removal spray. I had it on for about 1 min. Most of it was easy with just a little paper. Some parts were sticky so I had to use a plastic scraper and finish with more Sonax spray. Finally I used Sonax Wax to give it a nice finish.
(I used a fishing wire to slowly drag the reflex of after it was heated with the hair dryer.)
1 - 7 of 7 Posts
