1 - 4 of 4 Posts
This is on a '16 sixty2 . I unplugged and removed the purge valve as well. Plugged it back in after the engine light came on but of course it didn't go away. Anyone else have this problem?
Sorry. I just blocked the return hose from the canister, and extended the tank breather hose towards the lower left of the bike.
No warning lights...
After about the fifth time starting the bike the CEL went away. I'll have to figure out a resistor to put in place of the purge valve.
Discussion Starter #4
So, I picked up a .5 watt 150 ohm resistor at the local hardware store crimped a couple of connecters on to it and shrink wrapped it on to the plug. No check engine light! Now I have to grind all the brackets off the frame.
1 - 4 of 4 Posts
