1 - 4 of 4 Posts
Bought a Termi slip-on for my Cafe Racer. Is there a link pipe I can get to remove the catalytic converter?
Assume you’ve got the ‘race’ Termi?
44990
Not sure the chamber is a cat. Thought it was just a resonator chamber, to make the sound a bit more reasonable. The exhaust isn’t homologated for road use, so no reason it would have a cat.
If you want rid of that chamber, loads of other options for exhausts out there without it. SC project, Remus, Zard...
I confirm, the chamber is a resonator, not a catalytic converter, and it should come with the slip-on kit. There is a metal plate inside, directing air flows, and that's all. I had the whole kit changed under warranty 3 times (!) because the weldings of that metal plate fail after a thousand kilometers, due to some (well-documented) design flaw/manufacturing defect - search for "termignoni rattle"..
1 - 4 of 4 Posts
