Hello everyone,
After ever-worsening slipping, I replaced the clutch plates and put in new springs as well. I got it all back together but the clutch did not work at all - the cable is connected to the actuator on the clutch case and moves the actuator as it should, but after taking it apart again I'm not sure what is the correct way to turn the clutch activator so that is connects internally to the clutch?
Any help would be greatly appreciated!
Thank you,
Keith
Thank you,
Keith
