1 - 20 of 46 Posts
2016 FT. I don't see a lot of options for headlight replacement? If anyone has suggestions or links to where to but let me know please. When I look on revzilla for my particular bike I only see the Denali one so would just like other options.
Don't think there is the Denali one is sold under another brand too... but you need to fit all new fork mount headlight holders etc..
I added spots on my 800 and have just done the same on my 1100.
I ride early morning.. 4am... and the headlight.. even with higher output bulb (marginal improvement) was not good.
I added the Denali D2 - Dual intensity on fork mounts - high beam is now great.. but low beam could still be better (run at 5W at low beam and 10W on high) - so will add a second set of DM to see if I can improve further.
I had the Multistrada with the LED headlight... that was great... so I want to try and get similar illumination..
I would have prefered a better headlight.... to keep look standard... but also could not find something.
The electrical plug for the headlight is non standard. I have never seen a similar one on any other bike. I suspect that that may be a problem for OEM manufacturers.
1 - 20 of 46 Posts
