1 - 5 of 5 Posts
I recently installed some new turn signals - I've been meaning to replace the stock ones for a while now but never found the time. I was recommended these by a friend and I really like the look of them on the bike. Small enough to not be as noticeable but bright enough to get the point across. For the price of only $50 I'd say these are the best bang for the buck if you're looking to change out those bulky front turn signals.
I've been holding off making the swap just cause I knew I'd have to break out some soldering. Overall though it was a pretty easy switch, I may go back and clean up my wiring a little bit more but so far I'm super happy about the swap! Check out the video below to see what they look like!
45045
Those look good. Nice work.
I'm going to replace mine sometime this week.
Trying to finish up a tail tidy from NRC. I called and only ordered the tag re-locator (w/out tail lights) and am having some issues that require hacking from where the tail lights are installed back.
I have it half way together to see how it fits and it's pretty tight around where the key slot is to remove the seat. Will have to be creative :confused:
I'm really happy with how the turn signals came out - pretty cheap solution to those bulky stock ones.
I've got an NRC tail tidy as well - though I got the full package with the lights. Good luck with that! Hopefully there's a simple solution without having to get too creative!
yup. got rid of the tail and installed the plate re-locator. Was a bit time consuming for sure. Should've just bought the full set up!
1 - 5 of 5 Posts
