1 - 13 of 13 Posts
I bought a used urban enduro last week and when I tried to set the pin code, one was already saved. Is there a way that I can reset the pin code?
Thanks for any advice!
-Nadia
Discussion Starter · #5 ·
That only works if you know old one, dealer can change for you or try getting code from ex owner.
There might be other software, if you have local shop with Rexxer or similar, ask them
I suspected you may be right. When I tried to enter a new one, it had O: at the beginning--it wanted me to enter the old one. I believe it was from two owners ago so probably not likely. I may need to go to the dealer to get it changed. Thanks for the help!
Hi,
Did you get this done as I'm in a similar situation? Knowing Ducati it could be costly.
1 - 13 of 13 Posts
