Hopefully somebody will be able to answer a few questions I have in regard to Rexxer maps.
I have had a look at the various bits and pieces on the threads on here, but haven't managed to find the information I am looking for.
Firstly the bike is a 2016 Full Throttle with the standard Termi Shotgun exhausts.
NO mods as yet.
Planned engine mods in order are :-
1. Rexxer upgrade to sort out the terrible factory fuelling. I understand that I will get a mild performance upgrade also.
2. Different exhaust with cat delete (SC Projects single Conic or the CR-T are the ones grabbing my attention at the minute)
3. Airbox and filter upgrade.
Now from what I understand about Rexxer, there are 2 main options available.
1. Send your ECU away to be flashed to suit the modifications you have already made.
2. Buy the handheld unit?? and flash the ECU yourself with a more generic type map?
Please correct me if I am mistaken with any of that information above?
Because I initially want to fix the poor fuelling, and then upgrade the bike as I go along, I would like to buy the hand held unit and flash the ECU after each modification.
The questions I have are (and hopefully somebody will be able to give me some guidance)
1. Will the Rexxer work as I want with the standard bike set up?
2. Will I be able to reflash the ECU after each upgrade?
3. Are the handheld units available in the UK?
4. What is the approximate cost of the unit?
Thanks in advance.
NO mods as yet.
Thanks in advance.
