I just received word that Rexxer can now communicate fully with the ECU in the Scrambler.
If you are not familiar, this is the ONLY way to alter the fueling characteristics of this model that is reliable, effective and economical.
There are two options available...
This first is to purchase a Rexxer Tuning Module and Cable for personal use (cost is $600). This will enable you to re-flash the ECU as many times as you wish (for your particular bike only), and to be able to also control a wide variety of other parameters (such as reset of service indicators).
The second option is to send your ECU into Rexxer and they will re-flash for you. The cost for this service is $300 (one time), and you must provide them with the particulars of your setup (air filter type, exhaust type, etc.)
There are also optional services that can be programmed for additional cost, they are:
Immobilizer Disable - $100
O2 Sensor Disable
Exhaust Valve Disable - $100
Custom Dash Display Message - $100
Information on this (US only) is available here...
Rexxer ECU Tuning tune ups for European sports bikes and scooters in Yorktown VA a short drive away for customers in Newport News Norfolk Virginia Beach Chesapeake and Richmond
O2 Sensor Disable
