1 - 1 of 1 Posts
These are for a threaded M6 bolt. Took me 5 minutes to get them on my Sixty2 by using a dremel to shave the diameter of the plastic OEM bar ends so the RhinoMoto would fit over them. If that doesn't make sense it will be obvious and easy when you try to install them. I Used a longer M6 bolt than OEM and they went right over the OEM bar ends, into the OEM nut and tightened them up.
They also can hold CRG mirrors which I recently sold. With the CRG mirrors, they were just too wide for my liking.
Sean
Auto part Knockout punch Plastic Rim Wheel
1 - 1 of 1 Posts
