So I want to get the Rizoma wind screen but you have to buy other stuff to allow it to fit. I started with the gauge center thing-a-ma-bob. It is easy to install. Make sure you protect the finishes. I suggest covering the head light ring in blue painters tape. It is easy to scratch
. The gauge wiring needs to be rerouted. Watch for zip ties making the harness to taunt. The head light assembly has four attachment points. They are easy to access. You will need a 4mm, 5mm, 6mm, 8mm, allen sockets. Allen wrenches may work but the sockets are easy to work with. You will also need 8mm, 10mm, 14mm, 15mm wrenches. A torque wrench is needed as well. Rizoma's instructions are adequate. They don't mention loosing the head light assembly, again easy enough. The new stuff is lighter and is well made. See the pics below. A before and after.
