1 - 11 of 11 Posts
There are many threads about off road/dual tyres but I’m thinking of putting a sticky pair of road tyres on for the winter ... any suggestions ?
What tires are fitted now? Unless it's a very aggressive knobby or you plan on doing some hard cornering on very cold roads you'd be fine on most road biased dirt capable tires.
I have the stock tires on but they are coming to the end of their life ... and I don’t know where you are from but the country English roads in the winter are kinda terrifying... greasy wet muddy etc ..I’m thinking a pair of Angel Gt Will put more rubber on the road ..
I'm from Maryland in the "Colonies" ;) so it's a similar climate. Realistically here at least you aren't going to be riding too aggressively when it's 10-40F so the difference in compounds between the factory tires and most road tires aren't going to make a huge difference in my experience. The bigger difference is fresh rubber vs worn out skins. That said if you decide to go with road tires for winter use I have never had a bad experience with Angel GTs or Road 5s.
We have a legitimate road hazard known as "leafers". Folks that stop in the middle of the road to take pictures of the foliage. It's lovely, but my god man, just pull over!
No Angel GT’s in 19” front afaik.
You could give Conti Road Attack 3 a try. They are considered among the best in wet weather.
Or Bridgestone AX41S.
Both high silica tires.
Pretty sure the Michelin Pilot Road's are generally considered the best wet weather tyres. they have those really ugly looking sipes and circular reservoirs that do a really good job of shifting water.
Importantly over winter, you want a tyre that works from cold, as temps are going to be low. So you're limited to sports touring really.
1 - 11 of 11 Posts
