That looks fine to me. I was thinking of doing the same, any issues with the cable lengths?View attachment 28865 Being of short arms, I put a set of 2” Rox Risers on my DS to move the bars back towards me a little. They look a little weird but do what I needed. I also ordered a black mini windscreen so it should hide a little of the weirdness. I guess we do what we have to when searching for comfort.
Thanks man, I also have the heated grips installed, so that's good to know. Another quick question: the riser looks like a very tight fit over the OEM bracket. Does it allow the full pivot range of the Rox riser? or is it limited to either vertical or horizontal position (as you have it installed)?I had to remove the rubber straps and wiggle the cables around a little to get some slack. I later had the dealer add heated grips and while he had the tank off , they got a little more slack and put the straps back on. No problems
What handguards to you have?not many choices if you have short arms, also though about the Rox Risers, but ended ordering the Rizoma Riser Kit gauge relocation bracket that positions the gauge centrally and Rizoma handle bar MA009 in black.
If you feel comfortable with that set up, then keep enjoying you're bike.:thumbsup:
So two years later, how has it been? I saw your idea and got some too and tried it out, with it being set up like that, it felt sketch to me at first, any issues with it pivoting while riding or sliding off?From flat to upright and all in between. I had no problems.
I have Rox risers on my Groms (with different bars) and have used them on Moab rock-crawling four-wheelers. Their products are excellent and can really make a positive difference when needed. I have not tried them on the Ducati motorcycles, but I would recommend their products, in general.So two years later, how has it been? I saw your idea and got some too and tried it out, with it being set up like that, it felt sketch to me at first, any issues with it pivoting while riding or sliding off?
