Hey everyone, so i figured since I had to take the old exhaust off to get to the mesh filter to change the oil I thought I would be responsible and replace it with an aftermarket exhaust. Chose the SC project conic silencer and it sounds amazing and is not as heavy as the brick the factory put on. The issue is where the exhaust itself mounts onto the bike. The top image is how the pipe arrived from Italy, however the clearance between the pipe and the swingarm is so small that it can hold a credit card tight enough its difficult to pull out. Right now i have swapped it so the bracket faces outward, and I have a considerably less nerve wracking clearance, though the springs clipping the SC to the aftermarket go at a little bit of an angle. I seem to see a mix on youtube of the bracket facing outward and inward, I'm thinking it should be fine kicking out a bit further from the bike, I cant see it causing any harm this way. Anyone familiar with this exhaust that found the proper solution?
