1 - 3 of 3 Posts
Has anyone fitted a Scottoiler to the Scrambler? I've used it on a couple of bikes in the past and it works well with much longer gaps between chain adjustments and much longer chain and sprocket life. Unfortunately Scottoiler don't do a dedicated unit for the Scrambler so I'm not sure where I would connect the vacuum pipe.
If you haven't done this already, I've just done it. Info on the Scottoiler website and online generally is poor I agree. It took me a long time and I dismantled a lot more of the bike than I needed to. Very please with the result though I used the
Scottoiler Vsystem Sport bought from Amazon: https://www.amazon.co.uk/Scottoiler-Vsystem-Sport/dp/B01GS7L6ZQ/ref=cm_cr_othr_d_product_top?ie=UTF8 for £87.95
I started removing the airbox and throttle slide, which needed the tank removing. I couldn't get the airbox out and couldn't get see the vacuum point shown in this post: Scrambler - (2015 >) I've uploaded the picture of the vacuum point I couldn't see or get to.
Instead I connected the vacuum at one of the flexible rubber hoses behind the right hand cover below the tank. I had removed the fuel tank by this stage and I'm not sure if I would have been able to do it without removing the tank.
The sequence of photos here Ducati Scrambler were useful and show where I connected the T-piece for the vacuum connection. Very tight on space and fiddly to do. (but I'm new to working on bikes.. much less space than cars!) I didn't locate the oiler reservoir under the seat as shown in this article, but on the frame tube at the left hand side also shown in the this photo sequence.
Motor vehicle Auto part Engine Vehicle Car
Auto part Engine Motor vehicle Fuel line Vehicle
Yep fitted to my 1100 scrambler
1 - 3 of 3 Posts
