1 - 4 of 4 Posts
Hey,
I tried searching for side carrier options for my 2021 Scrambler 1100.
SW-Motech used to sell for previous year models (with one exhaust pipe each side under the seat).
But I am not able to find any option for 2021 model (with two exhaust pipe right side).
I am also fine with soft tail-bag, but I am not sure if silencer will melt the bags or burn it without a carrier.
Any tip / idea? Thanks
Hello, I have a Scrambler Sport 2018 with two pipes on the right, the same problem, I just decided to buy 1 Sw motech bag of 13.5 liters on the left side, I will install it in a week, just if you hang a bag with a larger volume, then you definitely need 2 of them, for balance, if you find a solution to this problem, write, I'm also interested
Hey,
The only one I could find that should/could work as it only mounts at the top.
finally my search ended here- Unit Garage has started building special parts for the 2021 model with two right-side exhausts.
link- Special parts
1 - 4 of 4 Posts
