How come there is not a Scrambler 1100 Section??
Just curious as to why you made the switch?Well
Said Good Bye to my 800 and Hello to 1100
Better photos to follow on 1100
BYE BYE
HELLO
800 looks better, better colour too.Well
BYE BYE
HELLO
You are not alone by any means. Mine is a 800 FTP. You have to really pressure the gear lever up and down. Try applying a little bit of pressure before you pull the clutch in. If you treat it like a normal box you are very likely to get a false neutral.Funny you mention that. I am a newbie. I thought it was me. Every once in a while I am going up through the gears and get a neutral instead of a 3, 4 , 5 or 6. So this happens to others as well?
2,400 miles and no change ('scuse the pun).I had the same issue on my 800 and Multistrada - plus difficulty finding neutral when you want to.
As the miles go on the bike - the problem gets less and up to now by 1000 miles the issue is gone.
My first Multistrada did occasionally have issues between 5th and 6th - but I think it was more me not being firm enough with the change.
When that happens can you go either way? I have to blip and go down. If I try to change up it just crunches. It doesn't matter which way I find the false neutral either.The only false neutral I get is when I’m lazy shifting from 6th to 5th.
If I shift “positive” I never hit a false neutral.
