1 - 20 of 21 Posts
Just for something different I decided to start tracking my FT Pro after a divorce, offloading my V4R race bike and close to a year off a bike i took my stock FT Pro to the track.
I had taken it a few times prior just for laughs but as i now had nothing else to go fast i decided to have a crack.
On standard suspension Angle GTs and a slip on SC Project CRT with AFM i was lapping ok in the one down from fast group. Through the corners the bike was keeping up but it was wildly dangerous, slipping sliding, bucking and dragging headers on the ground as it bottoms out….
a quick trip to CUBE Performance for some custom suspension and a few home jobs myself this things a weapon on the track. Corner speed is so good but it needs more hp. Next step is building a motor hopefully 100hp.
mods to date
All road gear removed
Nitron Fork Inserts
Nitron Rear Shock
Monster 1100 rear sets GP Shift
Metzeler Race Tec RR 110/80 K1 F and 180/55 K2 rear
Ebay flat bar kit
717 Grips
V4R Master Cylinder
Upgraded front pads
Rapid Bike Evo
1000rpm increased limiter
Rapid bike quick shifter
MWR Puk and Air Filter
48027
a quick trip to CUBE Performance for some custom suspension and a few home jobs myself this things a weapon on the track. Corner speed is so good but it needs more hp. Next step is building a motor hopefully 100-110 hp and this thing will keep up with the super sports guys (pros excluded) those guys are nuts.
mods to date
Nitron Fork Inserts
Nitron Rear Shock
Ebay flat bar kit
717 Grips
V4R Master Cylinder
Upgraded front pads
Rapid Bike Evo
awesome! I started tracking my FTP last year and following a similar path. I agree completely, it needs a little bit more power! It fits right in with the sv650’s out of the box.
The Metzler 18” front tire was not available so I went with the 17” cafe racer front wheel so I can run real sports rubber. Interested in seeing what you do with the motor.
mods to date
Nitron Fork Inserts
Nitron Rear Shock
Ebay flat bar kit
717 Grips
V4R Master Cylinder
Upgraded front pads
Rapid Bike Evo
Beast of a bike, I saw it at cube it looks like an Absolut weapon 👊✊🏍💨🔥😎👍
Interesting. Trying to decide if a power-up kit would be worth it or not. I'm not unhappy with the bike but a little more power would certaily be nice. So the Rapid Bike tune wouldn't need any special tuning? It just adapts and "figures" out the proper adjustments?
This is pretty awesome! I have a FTP and track it as well, bit of a different direction on styling though but I really like how yours looks. What belly pan is that? Take a look at mine.
Tire Wheel Vehicle Motorcycle Automotive tire
Tire Sky Helmet Sports equipment Vehicle
Running a 17" cafe racer front wheel with dunlop q3's, andreani cartridges and a tractive rear shock.
Discussion Starter · #10 ·
Very cool !!
belly pan is off an early monster, there are a few on eBay just need to trim around exhaust.
How are those Andreani cartridges working for you?
They're good to a point, I've been having some weird suspension geometry issues and It's almost tuned out, it took a lot of trial and error to get them where I want them handling. I've been getting this really bad high speed head shake when I hit a bump at 95 mph+, but besides that its perfect.
Hi there,
I sow your post on the forum of you tracking the scrambler. That’s awesome man, great bike.
I would like to start tracking my Icon and I have a few questions for you.
I plan on buying a rearset pegs kit to start. Should I buy the 17 inch front wheel from the Cafe Racer O leave the 18?
do I need to change rear suspension?
thanks so much in advance!
Discussion Starter · #18 ·
Hi there,
Hey Francesco,
I’m still running the 18” front wheel, only limited for tyre choice at track, I run Metzeler Race tec front and rear.
depending on how serious you are stick with the 18 and save your money and put towards suspension, the stock items will bottom out as soon as you start to push hard, again it all depends on how hard you
For rear sets I’ve been using cheap eBay items and they work great for $150AUD.
1 - 20 of 21 Posts
