1 - 6 of 6 Posts
Looking for a stand for the Italia Independent Scrambler and many of the stands on Revzilla state that they are for "spool type swingarms only."
I'm not sure what that means but is the Italia, or all Scramblers, spool type?
Thanks
Hello
It means that you need bobbins that fit in to the spindle.
Scramblers do not come with the bobbins as standard, so they will need to be bought separately.
The problem being that bobbins fixed in the rear axle are not at all interesting when you want to use the stand to remove the rear wheel...
Thanks
Perhaps something like this would suit you. The Bursig is expensive but I think there are cheaper stands that use the same method of lifting:
Bursig lift stand install
Thanks
Hi. Bit late with a reply - I'm new to the Forum. I've just purchased an Abba Superbike Stand, and it's great! So easy to use, and very stable. Go on Youtube and take a look. I'm in New Zealand. The local distributor delivered the stand within 30 hours, with a small tool tray as a Christmas extra!
1 - 6 of 6 Posts
