1 - 3 of 3 Posts
Brilliant little product.
It Works !!!!!!
Bit of a pain to install neatly, I had to cut the plug off, install the cable then solder the plug back on.
Took the switched live off the ABS fuse, indicator has minimal current drain.
Made a little black bracket to go below the left mirror.
I'm pleased.
Did you have to cut the harness (plug) so you could run and fit the cable all the way back to under the seat? Once you got it to the harness (plug) under the seat, did it simply just plug in or did you have any other wire's? Just ordered the same one. Thanks
I used gear position from japan
44832
1 - 3 of 3 Posts
