1 - 12 of 12 Posts
$80 + shipping
I used this on my icon for about 300 miles, it's still in great shape. All mounting hardware is included.
45341
Do you know if it will fit over the hex bolt knub on the K&N oil filter?
Mine is millimeters away from the bottom of my OEM oil filter after a good bash riding off-road, if you're buying this for real usage it a little soft. If you're riding off-road maybe get a stronger skid plate or pair this with an OEM filter. With the KN filter I imagine it would be touching.
Good luck!
Discussion Starter #5
Again, I had it fitted with the K&N filter and I used a few washers to create a gap so it wasn’t touching. It works fine
Yep I saw that post. Where in the States are you? You're including those washers etc in addition to the other hardware?
Discussion Starter #9
I'm sorry, I was never alerted to your comment. I'll include the washers, just $1 of washers from he hardware store. Everything you need to install is included. I'm in West Virginia.
It looks like shipping would be roughly $25
Thanks for the reply. Are you including the brackets I see in the instructions? How was it undoing the two exhaust bolts and the other two bolts to attach the brackets? I can't even make out on the instructions what the other two (non exhaust bolts) are?
I know you said, "including all hardware" but it's not in the image so I thought I'd ask.
Thanks.
Discussion Starter #12
All of the mounting hardware is included. It’s a 10 minute job to install. When you see the bracket with the bike, it makes sense.
1 - 12 of 12 Posts
