1 - 7 of 7 Posts
I have a 2019 DS with scratches in the fuel tank side panel. What’s the best way to remove the emblems ( so I can remove the side panel for painting). Then, more importantly, reattach them later?
Thanks, I’m sure many of you have done this.
I think there are a couple of methods kicking around – I used high strength fishing line to kind of 'saw' behind the badges. They came off fine and undamaged but I did need to clean residue off the panels. I bought some Scotch double-sided 'foam-tape' (can't remember the exact type) to re-attach. I did all this 4 years ago and they're still on there so I must have done something right ;).
I used Deano's method too. Hair dryer helps to melt the adhesive before the 'sawing' and dental floss works if you don't have fishing wire
Discussion Starter · #4 ·
Thanks to both you and Desmond for the info. I saw a video on how to remove as you’ve described- pretty straight forward. I was wondering if there would be enough adhesive left to reattach or what the best double sided tape is to use.
1 - 7 of 7 Posts
