1 - 1 of 1 Posts
Hello all,
thought I’d share my experience maybe help someone!
had the tank off to get it painted a few months ago and had a problem with a bit of water in the fuel filler 🙃
thought I was very careful when I put the tank back on but seems the drain pipe was kinked
i blew up the drain pipe and couldn’t blow through, loosened the tank slightly and blew up to find the bike covered in brown crud!
Fixed it by pulling a bit more hose up to the top and bolt the tank back down and tested by blowback up
one thing I did notice is that the fuel filler didnt have a o ring around the outside, so when you wash/rain etc any water can just sit down between the filler and the tank in the recess
have now made a oring but wondered if this was something it should have?
(I know the previous owner had the filler off as it was 180 out when I got it so perhaps they lost it!)
Automotive parking light Automotive tail & brake light Automotive tire Automotive lighting Hood
Bicycle tire Automotive tire Automotive lighting Motor vehicle Bicycle accessory
Tire Wheel Automotive tire Plant Tread
1 - 1 of 1 Posts
